Deletes the specified UPM log target.
| upm_profile_name | Specifies the name of the UPM log target to be deleted. |
N/A.
This command deletes the log target and any configurations applied to that target. To disable a target and retain the target configuration, use the following command:
disable log target upm {upm_profile_name}.The following command deletes the UPM log target testprofile1:
delete log target upm testprofile1
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
